Fuel filter location on a 97 Accord
RE: Fuel filter location on a 97 Accord
under the brake master cylinder ...like ovr said follow the top line /// the trick is to get a 14mm crow foot, a long extension and a rachet ..raise car, loosen the bottom line. lower car, remove the 17mm banjo bolt at the top, undo the lower line from the top u might want to put a pan under filter some fuild will spill. remove the 10mm bolt that attaches the fuel filter bracket and remove the filter/bracket assembly ..it is a bit of a tight fit but it will come out ,, once out remove the 10mm bolt and replace the filter ...............once u go back in,, firtst thing u do is start the bottom line from the top finger loose then put top all together and last thing do not forget to tighten bottom line
gary
05-24-2006 12:10 AM
