Sponsored by:
Sponsored by:
Is the fuel pump going out?
Old 08-09-2007, 11:18 AM
KY98Accord
Default Is the fuel pump going out?
Car is a 1998 Honda Accord coupe with V6
Car barely starts sometimes and then sputters when we first take off. We took it to Honda and they recreated the problem once but said they don't want to try anything till they know for sure what the problem is. I'm guessing the fuel pump is going out. The car has 160K miles on it and we've put 140K of those on it. We bought it slightly used in 2001. We've only had 1 other problem since we've owned it so it's been a great car. Any thing I should look for to know for sure if the pump is going out? I'm not a honda expert but I hope to learn. I've done all the mod work on my truck so I'm learning how to turn wrenches lol.
Thanks, Jeremy
Old 08-09-2007, 12:07 PM
Default RE: Is the fuel pump going out?
Honda fuel pumps are reliable but do occasionally fail. A failing fuel pump stops the car usually, and I've never heard of one that's partially working enough to actually start the car but cause poor performance. A blocked fuel filter, or failing fuel pressure regulator might cause this syptom. Why do you suspect fuel pump? Have you measured fuel pressure?
Old 08-09-2007, 12:18 PM
sir_nasty's Avatar
When it does it see if you can tell if it's getting spark and fuel... How many miles are on the car and what/when was the last time you did some tune up work on it?
Old 08-09-2007, 02:13 PM
KY98Accord
ORIGINAL: TexasHonda
Just a guess. I'll see about replacing the fuel filter. How can I test the fuel pressure regulator?
ORIGINAL: sir_nasty
Cars ahs 160K miles. Last time any tune up work was done had to be a few years ago when one of the cats was replaced.
Old 05-19-2011, 01:03 AM
Hi and hello. I found this thread on interwebs and it is relevant to my interests.
I have similar problem. Anyone knows how to replace filter?
Old 05-19-2011, 01:27 AM
Post in your signature area the particulars of your cars engine and so forth..by the way...did you notice this forum was from back in 2007 ?
Welcome To The 2011 Forums
Old 05-19-2011, 01:46 AM
I can not post much atm since I'm at work. Honda is at home since I cannot start it. There should be no problems with identifying model:
Honda ACCORD VII Coupe (CG) (1997.12 - 2003.06) 3.0 V6 24V 200KM
I try to post more at home.
Old 05-19-2011, 01:47 AM
Oh yes, I did notice 2007. Google did not.
rockhoundrob
04-11-2014 11:41 AM
Westjoe64
10-15-2012 12:11 PM
argarcia86
07-02-2012 06:46 PM
kissbally78
01-18-2009 07:14 PM
markinchico43
01-20-2008 08:34 PM
Quick Reply: Is the fuel pump going out?
