radiator hoses get tight
Old Mar 8, 2010 | 03:36 PM
accordlxman's Avatar
Default radiator hoses get tight
i just bought the car a couple weeks ago and it was overheating so i replaced the thermostat and water pump i let the air bleed out of the car and what is happening is that my radiator hoses are getting so tight at times that the bottom hose leaks a little im lost and i really want to keep my car. help how do i FIX THIS?????
Old Mar 8, 2010 | 04:04 PM
When hot, the hoses are supposed to get hard because of the pressure. But they're not supposed to leak. Maybe it needs a new hose.
Old Mar 9, 2010 | 07:39 AM
Default radiator cap
would an old radiator cap effect the pressure in the hoses also where is the best place to get the hoses right away?
Old Mar 9, 2010 | 08:36 AM
deserthonda's Avatar
get what is called cooling system hose kit from the honda dealer ,, that will include all the cooling system hoses, ( radiator, heater, bypass hoses ). it is best to do them all at once , will save you money and time versus doing them 1 at a time
Old Mar 9, 2010 | 10:01 AM
Difficult to tell just how hard the hoses get from a post on the web. A bad radiator cap CAN make the pressure too high. The rubber disk (part of the cap) is spring-loaded against the neck of the radiator, so if that spring action doesn't work the pressure will be wrong.
Caps can be pressure tested using a pump-type of thing that measures the pressure. Or if the cap is cruddy & doesn't operate smoothly, invest in a new one.
Old Mar 9, 2010 | 10:52 AM
hondadude's Avatar
Pressure test the system is my suggestion.
With a pressure tester in place on the radiator cap start the engine and let it warm up, to see what pressure gets up to.
Or if there is a big temp difference from the top hose and bottom hose after the engine idles 5 minutes, it could be a plugged up radiator.
Likewise top hose gets rock hard and bottom hose will squeeze easy.
vet67coupe
Aug 8, 2013 11:18 PM
accordlxman
Mar 17, 2010 09:57 AM
03Sleeper
Jul 10, 2007 10:33 PM
thunder_x
Feb 16, 2007 07:09 PM
HondaLawgik
Apr 22, 2006 01:05 PM
