Sponsored by:
Sponsored by:
starting issues
Old 03-20-2012, 06:54 PM
dragonman80917's Avatar
Default starting issues
Hello guys ,ok i have a 94 honda accord with the 2.2 L vtec engine. I have had it about two weeks, i just had the oil pressure switch replaced by a mechanic who also had to troubleshoot why i didnt have tail lights or dash lights.The issue witht he lights was some wires fused together at the license plate light .Now since coming back from the mechanic i have an issue with it not wanting to start after i get off work. It starts right up in the morning and started up at lunch, but when i went to leave at 430 it wouldnt start.So i thought well maybe the fuel gauge isnt working right so i went and got gas, still didnt start wouldnt start until i put some fuel down the intake it started and ran all the way home and even started up later. It started this morning,but again today after work i had to put fual in the intake for it to start.Anyone have any ideas? Im at a lose myself.
Old 03-21-2012, 08:57 AM
Any codes in the ecu?
In the afternoon, when this seems to happen, watch the CEL. When you turn the key to on/pos II (not start, the position the key would be when running), listen for the fuel pump to prime-the CEL should come on for ~3 seconds and then go off-Does it?
Old 03-21-2012, 07:40 PM
I ended up researching the problem on another site and found out what the problem was.It seems like a common problem with 90's model's, the main relay goes bad.It is the fuel pump and injector relay under the dash, watched a few videos on how to repair it did the repair and so far all seems well.
Old 03-22-2012, 05:51 PM
Yes, that is why I was asking about the CEL coming on for a few seconds and then going off.....and the fuel pump priming
Anyway glad you got it.
Slowaccord
08-28-2007 08:38 AM
sir_nasty
02-07-2007 04:19 PM
MRMASON
10-03-2006 07:09 PM
brad6841
05-22-2006 09:38 AM
brad6841
04-13-2006 06:20 AM
Quick Reply: starting issues
