Severe hard water Spots!!! What to DO?!!!
Old Aug 8, 2009 | 10:14 PM
jason.sloan0519's Avatar
Post Severe hard water Spots!!! What to DO?!!!
Car was just painted. long story short I park in my complex where I normally dont. wake up in the morning and the sprinklers got me. only problem is the water is so hard here in houston they wont come off. Ive tried washing and waxing but to no avail. any advice and none about that water vinegar mixture, tried that too didnt work Id apreciate some help fellas you are all pretty good at answering these kinds of questions for me. Thanks.
Old Aug 11, 2009 | 05:04 AM
jasonfridlund's Avatar
dude a clay bar kit by mothers will take care of any finish problem u have. it makes my car feel like glass
Old Aug 11, 2009 | 09:47 PM
I used come polich and a drill pad and it worked good but Ill take your advice and just do my whole car and then wax it. Thanks man!!!
Old Aug 11, 2009 | 09:48 PM
does the clay bar remove any clear coat problems I might have like spider webbing and fogginess in my clear coat on my hood?
Old Aug 11, 2009 | 11:31 PM
it will be better than almost anything else for under 500 bucks
Old Oct 10, 2009 | 01:07 PM
Okay Jason..did you or did you not get a clay bar and use it yet?
Or are you still spinning your wheels and not doing nothing ?
Comon fess up NOW !
Old Oct 11, 2009 | 10:00 PM
searich07's Avatar
Default Danase Water Spot Remover
Danase Water Spot Remover was formulated for detailers who demanded perfection without it taking all day to achieve. What was once a long drawn out process that took hours, now it is as simple as wipe on wipe off.
Danase will remove water spots and built up scum from paint, clearocat, and glass. Made from a mild acid base it breaks the bond between the mineral deposits and the surface.
www danase dot com ....no more direct limks, only like this one please...
8 oz $14.95
Regards
Richard
Last edited by WheelBrokerAng; Nov 29, 2009 at 07:20 PM. Reason: You Have Been Warned...
Old Oct 19, 2009 | 03:43 PM
no clay bar kit, just used polish and it came right off. Thanks guys
Old Oct 22, 2009 | 05:49 PM
glenfoxman
Default Severe hard water Spots What to DO
Im guessing a clay-bar system would do the job but it WILL be a lot of work. Sounds like you are washing it the correct way so once those spots are gone, get good coat of the wax of your choice on it, and you should be good to go.As an aside, I have heard that white vinegar will remove hard water spots but I am NOT advocating washing a car with it Perhaps some spot treatment using a soft cloth would get them up unless you have a lot of them and its back to the clay-bar.
Old Nov 5, 2009 | 10:49 PM
Gr8bald1's Avatar
Before going to the clay bar, try using white vinegar first. After a normal washing, use a 50/50 mix first 9 (with water). Then go full strength if necessary. Rinse completely.
John
San Diego
