engine swap
Old Nov 7, 2009 | 12:04 AM
90accordlx
Default engine swap
i'm considering putting in a jdm h22 vtec in my 90 accord lx soon is it gonna be an easy fit? and am i gonna have to make any mods to any motor mounts? and also will my existing trans work with the new motor?or am i gonna have to put a new one in? thnx
Old Nov 7, 2009 | 12:06 AM
90accordlx
srry forgot to put in there it's an automatic trans.
Old Nov 10, 2009 | 09:28 AM
KevinAccord's Avatar
i believe you're gonna have some issues w/ the tranny... have you checked if it's a direct fit?
Old Nov 20, 2009 | 03:43 PM
92accordwagon
well are you sueing the euro h22a and auto? or are you useing your stock auto?
and it doesn't matter what one you use cause theya re the same. size and motor mounts and etc. the stock f22 motor mounts will work. your axles will work the euro h22a and auto tranny are the same as a f22a and auto they are the same size and etc. the hard part is going to be wiring up the motor but thays its everything else is a bolt in swap. i've help my buddy put a h22a auto into is 90 honda lx coupe and it took ups about 8 hours to pull the stock motor/tranny clean up the enghine bay put the new motor/tranny in wire it up and get it running and driveing
D-Rod33
Nov 2, 2011 07:38 AM
hondahead23
May 9, 2011 08:55 AM
mfskarphedin
Jun 6, 2010 09:33 PM
StatzFinest
Feb 10, 2008 11:32 AM
