Will these wheels fit a 06 sedan?
Old Dec 7, 2009 | 02:56 AM
keywest909's Avatar
Default Will these wheels fit a 06 sedan?
I bought some used 18x7.5 diablo vienna rims with a 20 offset for a great price. Will these fit? What size tires should i get? I dont want to do 45, i prefer 40. I was thinking a 225/40/18 tire. Is this fine?
Old Dec 7, 2009 | 08:27 AM
20mm offset sounds way too low. Rubbing on the fender lips??
Old Dec 7, 2009 | 12:00 PM
Talking Hello Member KeyWest
20 mm No Good, Your car is a 5x114.3mm BP with a 64.1 mm hub-Your offset's can run from 42 to 55 mm without much problems of anykind...18" rims...with tires @ 225/40/18"...Hope this helps you out
Please click the picture
Attached Thumbnails Will these wheels fit a 06 sedan?-santa-christmas-deers.jpg
Old Dec 8, 2009 | 02:32 AM
keywest909's Avatar
Is there a way i can make them work? I paid a little over $100 for some nice looking rims. What about spacers? are they safe?
Old Dec 8, 2009 | 03:33 AM
keywest909's Avatar
Ok so i took a look at the well again on the inside, and this is what i saw. 18x7.5, and something looking like this 4l5. does this mean the offset is actually a +45? i got the earlier 20 offset from a website, where the person was selling the same rims.
Old Dec 8, 2009 | 03:46 AM
keywest909's Avatar
The inner wheel looked like this, with 4 and 5, instead of 2 and 5.
Old Dec 8, 2009 | 07:29 AM
You can measure the offset yourself if you wish. TireRack has a nice explanation of what offset really is.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Dec 8, 2009 | 03:35 PM
keywest909's Avatar
oh ok, thanks. What offsets do i need to be between, to be ok? and what size tire should use, if the offset is 45? I like either a 225/45 or 225/40
Old Dec 9, 2009 | 05:45 PM
finch13's Avatar
That stamp says: "ET: 25", meaning a +25mm offset on that wheel.
Are you sure the wheels are the correct bolt pattern? 5x114.3mm is what you need.
Generally on Accords, stock offset is around +55mm, and you max out around +45mm without suspension adjustments. So, a set of 20mm H&R or Eibach wheel spacers would do the trick. Do NOT cheap out on a spacer that thick. Without a spacer, the spokes may not clear the brake calipers, which would be more costly to replace than a small $100 investment in wheels.
Google "tire calculator" enter your stock tire size, then enter the new tire size (a 225 width is about right for those wheels), then change the aspect ratio (40, 45, etc.) until it matches best with the stock tire size.
Old Dec 10, 2009 | 02:45 AM
keywest909's Avatar
that's not my rim, i found that picture online, but mine looks like that but says a 4/5, i assume that means its a 45 offset.
im still confused so hears the measuments. from inner rim to inner rim the measurments is 7.5. From the inner mounting point where the bolts go, to the top of the rim i got 6". I think i came out with a measurement of 44. Does the mean my offset is 45.
