4dr to 2dr conversion
Old 06-13-2012, 08:23 PM
zakelrod's Avatar
Default 4dr to 2dr conversion
i have a 4dr i'd like to convert to a 2dr. i have seen other cars being pretty easy. however iwas wondering if a honda was been done or if was possible.
Old 06-14-2012, 07:25 AM
crispin's Avatar
Sure
1) Harbor Freight 120 volt welder
2) ??????
3) Profit
Old 06-19-2012, 01:15 PM
Mikebike125's Avatar
I think it would be easier and done a whole lot better if you just sold your car and bought a 2dr..... Call me crazy.
Old 06-19-2012, 03:21 PM
It's more than likely all in the challenge to do it as the 1st one...
That's what I think...
Old 06-19-2012, 05:14 PM
rhamza161's Avatar
^,^ Weld the seam and you have a 2dr car. Might want to swap your factory front seats with 2dr seats that slide forward all the way...unless you never want to get into the back seat again...? Bondo will be your friend as well. Cover the seams up, take the door handle off and cover with Bondo and you should have a 2dr easily.
CanI ask a question though? Why do you want to make a 4dr into a 2dr?
Old 06-23-2012, 10:00 PM
hondafreak91c's Avatar
To be honest, I seriously wonder why you are considering this. Its seems totally against logic. I know you want to try to be different, but sometimes its just not worth it.
As the guy in the post above me said, good luck ever getting in your back seat. Even if you get the coupe seats/rails, the seat will most likely not move up enough to get in. Have you ever seen how much longer a coupe's door's are? The B-pillar is back that far for a reason, for easy access.
Honda made an Accord coupe......I would would just sell your sedan and buy one.
I don't wanna appear to be a jerk, but I'm just having a hard time understanding the logic of this.........
What year is your car?
Old 06-25-2012, 12:43 AM
zakelrod's Avatar
well i can get two coupe doors and back windows and convert it to a normall two door.
Old 06-25-2012, 10:12 AM
grim_reaper's Avatar
how?? even if you did get, two coupe doors, they would quite fit directly and assuming they did, what are you going to do about the back doors?? you already have windows, you're not going to need coupe windows, that's pointless.. btw, this whole project is pointless but your money, so do as you please..
best bet, weld weld weld.. coupe front doors aren't all that much bigger than sedan front doors.. so not it won't work like that.. leave the front doors as is and weld out the backs.. remove handles etc etc.. basically you want to make it a sheet of metal with no seams in the back, instead of a door.. leave the windows, no point in taking them out.. btw, the car is going to look seriously awkward..
Old 06-27-2012, 11:01 PM
rhamza161's Avatar
It will not be a normal 2 door car after you do that...that is a fact.
camman
08-11-2013 09:17 PM
bigdawg74
05-09-2013 10:39 PM
McDesign
08-17-2011 03:57 PM
my2khonda
03-10-2007 10:32 PM
iiisoysauceiii
03-30-2005 09:44 AM
Quick Reply: 4dr to 2dr conversion
