Any Rim suggestions!?!?!?!
Old Apr 29, 2006 | 11:36 PM
JT 03
Default Any Rim suggestions!?!?!?!
Hey everyone. i have a 2003 honda accord ex charcoal grey and i am very intrested in making it look good.
does any one have any ideas for rims that would look good with this year and color????
every opinion matters !!!!
Old Apr 30, 2006 | 11:59 AM
flomasta's Avatar
Default RE: Any Rim suggestions!?!?!?!
Hey check out the Konig prophets, or the motegi dp6's. im getin the motegi's on my '96 but i think they would look good on your car.
Welcome to HAF[sm=welcomesign.gif]
Old May 5, 2006 | 01:44 PM
dholla147's Avatar
I also want to get rims for my 03 Accord but my dad was telling me I need to make sure the offset is right. Would any of you know the offset by chance? I want to get 17" rims, so whats the proper size of the rim and tire I should look into. This modification stuff is new to me so Id appreciate any help...
Old May 7, 2006 | 11:49 AM
RoXeTTeMaN's Avatar
I'm almost sure that 35-45mm offset would do the job and rims need to have 114.3 bolt pattern. If someone believes I'm wrong, please correct me.
Old May 7, 2006 | 08:16 PM
Breeze's Avatar
I have 17" Konig Imagines with Kumho 711's. Tire size P215/40R-17. Konigs are nice looking rims but I have found that when I put Kumho ecsta asx 215/45R-17 on the Konig rims I had alot of problems with busted rims. I replaced 3 rims during the time I had these tires on the rims. When these tires were on I had to watch out for any road imperfection. Now that I have the Kumho 711's on I have yet to have a bent rim and I have hit some pretty questionable holes. I really don't understand why those other tires were different but the new ones work great. Good luck. I also suggest to make sure you buy your tires and rims at a place were they do alignment, balancing, and have knowledge about chamber. My 96 Accord had to have camber kits installed when I got the new rims and tires and the place I bought the rims and tires from didn't let me know this untill after three months of use and the tires were ruined. Be sure that you take it to a place that performs these key things because Honda's do not have chamber adjustments. Your tires will wear excessively on the insides of tread or the outsides if they are not adjusted right. I hope this helps.
Old May 7, 2006 | 11:58 PM
benjiaccord's Avatar
One other thing, I agree with the last post that when you get tires make sure you get something good. I loved my Kumho 711's but unfortunately they don't make them anymore. The 712s are pretty good but a bit overpriced compared to the quality you got with the 711s ultimately Toyo Proxes T1-s is an amazing tire. But for 17s you are looking at close to $200 depending on where you get them at. Maybe you can get a better price on line?
chris9estes
Jun 12, 2013 03:03 PM
RI Jon
Jun 8, 2013 01:08 PM
phi1542
Mar 24, 2013 12:53 PM
ryan48
Oct 31, 2010 03:22 PM
Cody Is Cool
Mar 11, 2007 10:19 PM
