Cluster and Dash bulb question
Hi everyone, I tried seraching this but could not find any results. I drive a 2000 Accord Coupe LX and I wanted to change the colour of my dash and cluster bulbsto red insteadof the stock greenish/yellow. Any suggestions?
Thanks!
Thanks!
just find your bulb styles/numbers and remove the guage cluster, then change the bulbs out. Getting the cluster/assembly out is the hardest part but getting replacement bulbs in is quite easy.
Try http://www.automotiveled.com/ or http://www.superbrightleds.com The LED bulbs should be much brighter and can still be dimmed. Just so you know before you go ahead and change the color, my 95 has a bluish tinted plastic diffuser to spread the light around and when I changed my bulbs to red, did it cheap with red transparent tape, they came out a little purple and dim. I've wanted to do the LED conversion for a while now so post some pictures if you go through with it.
Actually, check the superbrightleds site. They have a bunch of different angles and leds that help diffuse light. If you still want to go old school I have some red 194 type bulbs that I got at Wal-Mart or Checker, so they are around.
sskkf
Jan 19, 2007 04:23 PM
