Replace bulb in cluster panel
Old May 9, 2007 | 11:05 PM
humblehyper's Avatar
Default Replace bulb in cluster panel
Hello guys, does anyone know how to replace the bulb in the cluster panel? My "D" light is out. Is there any website that shows in detail (with pictures) on how to remove the cluster panel to replace the bulb. I have a 2000 Honda Accord LX Auto. Thanks so much.
Old Jun 12, 2007 | 06:10 PM
acuragod
Default RE: Replace bulb in cluster panel
Mine went out the other day too! I just hit the cluster with my hand and it came back on.
Old Oct 9, 2007 | 04:34 PM
Prizma's Avatar
Argh they probably won't get this but what do you mean your "d" light went out? Are all the other drive lights working? Just not the D one?
Mine starting doing that too. Long story short, I pulled the cluster out and there appears to be only one bulb that lights up all of the drive lights.... I'm at a loss as to why the "D" would be going out.
I, too am struggling to find a website that shows the bulbs in the back. When I pulled the cluster out yesterday to replace the bulb for the speedometre on the right side, I discovered there are 3 different types of bulbs back there. I was not amused since I stocked up on the other bulbs. This next round, I'm going to take pictures. Hopefully that will help others.
Old Oct 9, 2007 | 04:41 PM
00AccordLX5spd's Avatar
Registered User
That would be awesome This seems to be a pretty hot topic. Removing the cluster is a PITA. Apparently you have to remove the console, radio, etc...
There should be instructions on one of the sites found in the DIY section. 4th post from the top by deserthonda. Links you to a site that shows a free chilton manual to almost any type of car. Haynes also shows the procedure, but you gotta buy one of those for about $15 or $20.
Old Oct 9, 2007 | 04:52 PM
Prizma's Avatar
I've got the Hayes book and honestly it was good for a basic guide, but if you've got eyeballs, you can take the cluster out.
The first time I did it, I pretty much had most of the dash off. This was also due to the fact I needed to find out why the car was dying on me for fun... especially in traffic. [>:]
This last time, all I did was take off the steering wheel covers, attacked all the screws, removed the cluster plate, and bingo. Had the cluster out.
Accordlx5spd: I think I saw the link you're referring to in regards to the bulbs at the back. All it showed was how to make the console blue and pretty when the lights were on. I'm still only half way searching through the site so I'm sure something will pop up.
Old Oct 9, 2007 | 05:04 PM
Registered User
I was referring to the link that leads to the online Chilton manual. But I know a lot of times Chilton and Haynes are both kind of worthless[&o]
manbeing99
Feb 8, 2020 09:35 PM
19962door
Nov 12, 2009 09:27 PM
artanis7
Aug 17, 2007 01:42 PM
Bernman
Mar 18, 2007 03:52 PM
sskkf
Jan 19, 2007 04:23 PM
