fade clear coat ?
Old Oct 17, 2013 | 01:15 AM
Mello Gonzalez's Avatar
Default fade clear coat ?
Hi everyone, I have a honda 1998 honda accord v6 which I purchased recently. On the back left side door is a spot about a baseball ball size that the clear coat if fade. I like to know if is posible to restore just using a spray and hand. I don't have ano polishing machine or the money for it. All that fromt bumper is black, the previous owner changed and didn't painted. Can I just buy the car color paint and spray it on the bumper? Thank you for your response.
Old Oct 17, 2013 | 03:17 PM
You can get that at your fav parts store..it works well.
Old Oct 18, 2013 | 08:02 AM
MysticBlueEX's Avatar
Almost A Senior Member
I had some luck fixing up the clearcoat on my lower door panels using Duplicolor Wheel Coating clear. I wet sanded the panel with 1000 grip sandpaper then used about 3 light coats of clear. Didn't really look like factory finish. It is thicker. But brought shine to the panel and kept it from getting worse.
Old Oct 18, 2013 | 02:25 PM
Better than getting worse for sure..but are you okay with what you got out of it?
Old Oct 19, 2013 | 12:06 PM
I did this when I first got the car, there were some deep scratches just about down to the metal, along the rear door below the trim strip. I used that little jar of touch up paint to fill it in, then the next week sprayed with clear. It cost nothing except the 1000 grit paper from the parts store, because I had the other materials lying around. Hasn't rusted yet 3 years later.
rogersah
Feb 3, 2013 03:12 PM
Zer0Vtak
Feb 21, 2008 12:07 AM
sir_nasty
May 14, 2007 04:01 PM
maro
May 7, 2007 04:10 PM
YeuEmMaiMai
May 29, 2006 05:09 PM
