Help with installing triple gauge pod 94 accord
Old Sep 16, 2011 | 03:52 PM
Cali94Accord's Avatar
Default Help with installing triple gauge pod 94 accord
Hey all, new to this forum. I need some help and advice with installing my new gauge pod. To be more specific its a triple pillar pod with oil temperature and pressure and volt gauges. Any help with how to install and wire the gauges would be very helpful!
Thanks!
Old Sep 17, 2011 | 08:18 AM
Not sure what kind of help or advice you are looking for?
Old Sep 17, 2011 | 12:32 PM
Im mainly looking for how to wire the gauges so they work properly. I know how to install the trim piece just unsure how to wire the gauges for oil pressure/temperature and the voltage.
Old Sep 17, 2011 | 03:08 PM
Are these elec or mech gauges?
Are you wanting the temp/oil light gauge on the dash as well or just the ones one the piler?
Again just want to understand.
Anyway, for the temp, the sensor is on the head under the dist, single wire. Oil will come from the back (firewall) above the oil filter (remove the filter for ease).
If you want both to work you'll need some extra fittings to tee off from where the OE sensors go.
Oil
Old Sep 22, 2011 | 12:03 AM
Bump. These are mechanical gauges.
Old Sep 22, 2011 | 12:05 AM
Electrical*
Old Sep 22, 2011 | 05:06 PM
The oil switch is on the back side of the block above the oil filter. The temp sending unit is the single wire sensor on the head under the distributor-only concern would be the size of the sensor that came with the gauges. Not sure how the volt meter wires in, do you have the instructions. If so we can help with which wire to "tap into".
deerhunter1525
Jun 18, 2010 12:38 AM
timthoeun
Sep 17, 2008 08:53 AM
timthoeun
Sep 14, 2008 11:37 AM
rhrhkdals
Jun 1, 2007 10:36 AM
90f22assasin
Aug 24, 2006 02:49 AM
