Installing Carbon Fiber Hood in 03 accord coupe
Old Mar 28, 2007 | 06:22 AM
Khonsaiho
Default Installing Carbon Fiber Hood in 03 accord coupe
I purchased a custom carbon fiber hood for my accord 03 coupe. Nicely made hood, but the makers did not install a bolt inside the drilled holes to secure the nut to attach the hole. I really want to find a way to install.
Does anyone have any ideas?
So far, I'm thinking of forcing a cap inside each hole so the nut will secure on. The hole is currently 10mm in diameter. I can get a 10mm cap.. + epoxy glue
Comments??
Old Mar 28, 2007 | 07:07 PM
sir_nasty's Avatar
Default RE: Installing Carbon Fiber Hood in 03 accord coupe
if I understand you correctly you've just got 4 holes on either side of the hood that don't go all the way through? can you access the backside of them to get a wrench on if you were to use some washers/nuts?
blackex19
Jan 14, 2012 05:02 PM
jdmaccord1215
Dec 4, 2009 02:27 AM
rdsxntn19
May 5, 2009 11:17 PM
Xv7vX
Jan 29, 2008 04:21 PM
pyaarawala
Jun 28, 2007 06:26 PM
