LX 2001 Headlight Lenses starting to cloud
Old Feb 13, 2008 | 05:28 AM
enatal
Default LX 2001 Headlight Lenses starting to cloud
Hello.
My Accord LX 2001 headlight lenses are starting to cloud on the top. Is there any solution to bring them back to clear?
Please advise
Thanks
Old Feb 13, 2008 | 07:36 AM
ikethegreat's Avatar
Default RE: LX 2001 Headlight Lenses starting to cloud
My tail lights used to fog up. I drilled several small holes in the bottom of the light to let air in and that solved it.
Old Feb 13, 2008 | 08:37 AM
02BlueAccord's Avatar
are they fogging or did the sun damage them?
Old Feb 13, 2008 | 09:43 AM
enatal
Hello.
Thanks for the responses.
The headlights do not fog. They are not "yellowish" (sun damage) either, the "cloud" is on the top part of the lens.
Old Feb 13, 2008 | 12:27 PM
finch13's Avatar
Weathered headlights from road salt and age appear to peel and flake. Headlights with a bad seal will generate moisture on the inside. They are easy to tell apart, which one is it?
For weathered lights, mask off around the light with masking tape and use a plastic polish like PlastX with a buffer to retuurn them to clear.
For moisture, remove the bulbs from the lights and allow them to circulate air in and dry out, then make sure the rubber gasket around the bulb is in good condition. Silicone grease on that wouldn't hurt either.
Old Feb 13, 2008 | 04:45 PM
00accorddriva's Avatar
mine were kind of blurry on the outside so i grabbed some micrfinishing compound and the buffer and hit them for a few minutes. let me tell you i was impressed helped alot. especially at night. it was getting to the point where i couldnt see very good without the fog lamps on.
Old Feb 14, 2008 | 05:11 AM
enatal
Hello.
The "cloudiness" does not come from moisture. When touch the lenses, I can feel the roughness in the outside surface.
Thanks
Old Feb 14, 2008 | 06:35 AM
enatal, some times they do get moisture in them as some of the guys stated and yes like mine they do get a bit blurry. from road debris and stuff.
Try getting some plastic compound and bufing it out. if not headlights are very cheap on ebay.
Old Feb 14, 2008 | 08:49 AM
yea u can do that or i know there is ppl out there that will sand down ur whole light and redo the plastic for cheap and make them look new or if it comes to that u mind as well buy new headlights like maybe some projectors or something
dean1492
Nov 13, 2013 04:47 PM
Tony1M
Jul 25, 2010 05:15 PM
HondaAccordEX94
Apr 5, 2010 03:44 PM
ricekillinN204.3
Jul 24, 2008 12:24 AM
kyle.941
Mar 31, 2008 05:30 PM
