neon tubes or other lighting
Old May 16, 2007 | 08:52 PM
  #21
03Sleeper's Avatar
Default RE: neon tubes or other lighting
I don't think any Accord has a hood light....boo on Honda.
Old May 16, 2007 | 09:38 PM
  #22
louisville_slugger89's Avatar
aight so i'm thinkin bout getting this set of led's
http://www.ledunderbody.com/index.as...&ProdID=65
1 it's cheap
2 it looks easy to take care of/install
3 it has the fur seperate lights i wanted all wired into one power source
4 it has a easy to use switch
tell me what you think of it
Old May 17, 2007 | 12:17 AM
  #23
accord93's Avatar
nicely done tat will look tite man, put pics up of ur car once you have that in!
Old May 17, 2007 | 07:51 AM
  #24
03Sleeper's Avatar
Those LED tubes look pretty sweet....put up pics once you install them...and rate the level of difficulty of mod!
Old May 18, 2007 | 10:02 AM
  #25
accord93's Avatar
i have streetglow underglow on my car(neoblue) and it was really easy to do. my friend knew how to do the wiring so he did that while i screwed it into the bottom.
Old May 18, 2007 | 11:11 AM
  #26
1996AccordLX's Avatar
It is really simple, just wire it up to an open post on your fusebox instead of directly yo your battery. I find it much more simple. But be careful whatever you do don't go too fast over the speed bumps or bumps in general, i ripped off a tube on the right side of my civic because i bottomed out, so be careful!!
Old May 18, 2007 | 06:58 PM
  #27
Fenix's Avatar
Old May 18, 2007 | 08:19 PM
  #28
thanks for the pictures Fenix
does it have the same switch too?
if so where did you put it and where/what is your power source?
Old May 18, 2007 | 10:55 PM
  #29
Fenix's Avatar
my kit came with a controler/distributer box, that the leds plugged into. but it did have the same switch. i put the switch in the glove box and snaked the wires behind the center console. And hooked the whole system up to a toggle switch so all i have to do is flip the switch and the lights are glowing. Ill tell you this, when its done right it looks great. And those picsi took are only of the blue color, i have it fade through all 7 colors. Looks great. Took me bout and hour, the toughest part was actually placing the rods so you cant see them.
Old May 19, 2007 | 11:10 PM
  #30
ORIGINAL: louisville_slugger89
Wire it up to your fusebox, that's what i used as my power source for mine and my friends kit
