razo shift knob
Old Jun 30, 2007 | 07:32 AM
dfresh1121's Avatar
Default razo shift ****
HI i have a 2004 accord 5 spd and i just got the ra 95 shift **** razo and when i removed the factory ****, and placed the razo on it fit perfectly except i dont know where the boot goes, it has two clips on the top of it and they clip onto the factory **** pieces but im lost with the new one with what to do with the boot because they do not snap into the razo. thanks
Old Jun 30, 2007 | 04:07 PM
sir_nasty's Avatar
Default RE: razo shift ****
without seeing that exact setup I can give you an idea... snip a TINY hole in the seam of the boot about 1/4 inch down from the top. Pull the boot down and wrap a zip tie very loosely around the shifter just below the ****, pull the boot back up, slip the "tail" of the zip tie through that little hole, then pull the boot over the outside of the zip tie and wrap the remaining 1/4 inch around and down inside the inner loop of the zip tie so the boot now covers it and runs inbetween the zip tie and the shifter, now just cinch up the zip, clip off the extra and it should hold it in place and be covered.
Old Jul 1, 2007 | 06:11 PM
jimmyznutz
^^^^x2
Old Jul 1, 2007 | 11:24 PM
dfresh1121's Avatar
sorry dont know what the x2 thing means, and also sir nasty i didnt want the shift boot going over the shift ****, the way you explain it it seems like thats how it would be, i would like it under cuz of the appearance, but i may be just confused too on thaat aspect
rydnlow1120
11
Nov 11, 2015 05:29 PM
wanted_honda
Sep 12, 2009 07:31 PM
Honda_Dude
Mar 10, 2007 11:14 PM
sir_nasty
Apr 7, 2006 05:54 PM
misterwebb
Sep 11, 2005 03:25 AM
