REMOVING REAR DOOR PANEL 90 ACCORD
Old Sep 28, 2006 | 11:21 AM
RBG
Default REMOVING REAR DOOR PANEL 90 ACCORD
I have it most undone. I have pull from the bottom aND popped all the plastic clips, I have removed the screw from the arm rest and the one in the door handle LATCH? cup. The whole panel seems to loose I can move/rock it but it seems to be attached rgiht behind the door latch mechanism. Any ideas???
THANKS!!!
Old Sep 28, 2006 | 07:06 PM
19Accord97
Default RE: REMOVING REAR DOOR PANEL 90 ACCORD
did you remove the pin that goes from right behind the inside door handle to a little clip? The handle should be surronded by a plastic piece that can be removed but wont come all the way out because of that pin. Its like a steel horizontal rod and you should just pop it out.
........_________
.......I...............I
......Handle
Ignore the dots, but behind the handle mounting piece there is a rod from the handle to another clip, (mine was pink)
Jaretr1
May 2, 2013 10:12 AM
pham9006
Jul 7, 2008 04:38 PM
gtchen66
Aug 17, 2007 12:05 AM
segentry@aol.com
Apr 16, 2007 10:37 PM
RBG
Sep 28, 2006 11:31 AM
