Removing Side Mirrors?
Old Oct 2, 2006 | 03:26 PM
WhyNotFab's Avatar
Default Removing Side Mirrors?
On this older model Accord that my friend owns, he removed the side mirrors, used diamond plate to make a filler that just bolted right in using 3 bolts. He then capped those 3 bolts with chrome bolt head caps, then bolted billet chopper mirrors on..
I'm going for a similar look, but until I can afford the mirrors.. I was wondering if on my 1996 model, if I remove the mirrors (power) will there be 3 similar mounting holes that I could use to bolt my triangle shaped sheetmetal filler in place?
I'd be painting the metal the same color as my car, and instead of the ugly looking bolt heads sticking through showing.. I'm planning on tack welding the bolts to the inside, so it's all one solid assembly with no bolts showing, easily accessible from the inside.
Let me know if you know what's under the mirror piece if I take it off!
Old Oct 3, 2006 | 04:41 AM
Slusher's Avatar
Default RE: Removing Side Mirrors?
Yes, you will have three bolts that actually hold the mirror on and an elctrical connector for the mirror part. I think you just remove that plastic cover and then you will see the nuts to remove.
gunsnroses316
18
Dec 17, 2008 08:07 PM
rob3201
Apr 3, 2007 10:28 PM
jjyynnxx
Oct 12, 2006 09:55 PM
2002haccord
Jul 3, 2006 04:35 PM
XaccordboiX
Jun 7, 2005 12:07 PM
