Replacing side mirror
Old Jan 5, 2008 | 10:57 AM
jper
Default Replacing side mirror
Right side mirror cracked, houosing is fine. Bought replacement mirror at Honda...How does one install it? It has self stick on the back, how do I get old mirror off and new one on.
Thanks much
Jeff
Jeffperkell@rcn.com
2003 4 dr EX-V6
Old Jan 5, 2008 | 11:42 AM
sir_nasty's Avatar
Default RE: Replacing side mirror
if you purchased just the glass then you'll want to pop off the inside cover (just held on with clips, gently pry with a screwdriver) then look under the mirror and there should be a screw or to (or perhaps they are covered) you'll need to remove those then gently "wiggle" out the assmebly, seperate the glass, install the new piece and re-install very carefully.
Either that or just stick the new piece to the old piece over the top (not the right way obviously....)
Welcome to the forum!
iimzii85
Nov 1, 2010 01:16 PM
JohnnyGreenHonda
Jul 4, 2010 12:07 AM
ndp
Jun 7, 2009 05:23 PM
rose92
Jan 9, 2006 11:23 AM
