Sandpaper
Hi..
My car hood have rust and I want to sand it down then paint it. Which type of sandpaper should I get? thanks |
This may be better in the Appearance section, so I'll move it.
use 220 to remove the paint, spray it, use a wood block and wrap 400 grit sandpaper around it, then "block sand" between coats of primer to produce a perfect surface. then block sound with 600 grit and paint.
Hi New Member
1 Attachment(s)
Originally Posted by TSprag
(Post 227012)
WheelBrokerAng |
