Sandpaper
Old Jan 11, 2011 | 01:02 PM
kennilope's Avatar
Default Sandpaper
Hi..
My car hood have rust and I want to sand it down then paint it.
Which type of sandpaper should I get?
thanks
Old Jan 12, 2011 | 10:45 AM
This may be better in the Appearance section, so I'll move it.
Old Jan 13, 2011 | 04:35 PM
TSprag's Avatar
use 220 to remove the paint, spray it, use a wood block and wrap 400 grit sandpaper around it, then "block sand" between coats of primer to produce a perfect surface. then block sound with 600 grit and paint.
Old Jan 13, 2011 | 04:56 PM
Arrow Hi New Member
Thank You for helping with this post..good info.
