Wiring for Headlight LED's???
Old Apr 28, 2008 | 12:38 PM
98CoupeW/Carbon
Default Wiring for Headlight LED's???
I have the projector beam headlights with the LED BMW style rings and I need to know how to wire them up.
The wires for the led's(red & Black)are seperate from the normal headlights and turn signals.
can anyone give me some advice for the best way to wire these, currently I have them spliced directly into the headlight wires but I'd like to do it proper and I would like to wire them to a switch next to the cruise control button on the dash so I can turn them on and off at will.
Thanks in advance for the suggestions
Old Apr 28, 2008 | 12:43 PM
finch13's Avatar
Default RE: Wiring for Headlight LED's???
I had mine spliced into my parking lights and they worked great. If you want them switched, create a new positive lead from the fuse panel, run a 1 amp inline fuse, then run it to the positive terminal on your switch, then connect the negative to any grounding point on the chassis. Same goes for the negative on the LED lead.
Old May 11, 2008 | 03:12 PM
98CoupeW/Carbon
df
tobybul
Dec 20, 2013 02:26 PM
brandondgordon
May 4, 2013 08:27 PM
Albert W
Dec 10, 2012 04:34 PM
Cody_754
May 28, 2012 02:45 PM
timgeorgi
Mar 2, 2008 06:12 PM
