00 EX Steering Wheel Controls
Old Aug 27, 2006 | 09:43 PM
BigShelby's Avatar
Default 00 EX Steering Wheel Controls
00 EX Steering Wheel Controls...
Factory HU CD player inop. Time to replace this gem. I have an older Sony Mobile ES HU that I want to add but it's not remote compatible. I think I might add the Sony HU but will have to sacrifice the factory wheel controls. I don't want to buy a HU if I can avoid it and then have to buy the (PAC) steering wheel control adapter. I'm looking at $500+ for the quality I need.
Does anyone know if you can remove the factory steering wheel audio controls and replace it with some type of factory cover plate? Will removing the controls effect any other systems?
Thanks
________
Honda Vamos specifications
Old Sep 16, 2006 | 10:56 AM
BigShelby's Avatar
Default RE: 00 EX Steering Wheel Controls
FYI...for anyone in this situation. After researcing the subject I found that the headunit was compatible with factory steering wheel controls via an adapter. I got the adapter from Crutchfield. There's no coverplate avial. if you want to remove the factoy steering wheel controls. It's made by PAC model SWI-PS about $69. The install wasn't too difficult, though programming wasn't that easy. It works almost as good as if the factory unit was installed. Most importantly the sound quality is lightyears ahead of the factory unit. I'm running the Sony Mobile EX headunit, JBL speakers, MTX 8" sub and Crossfire VRX-400 amp.
Old Oct 23, 2007 | 06:48 PM
klenoth
Did you hav to ground any wires on the original factory harnes?
Im trying to install this.
Do you know if the button on the factory steering wheel is just different resistors with a common ground?
robbo
Sep 21, 2011 10:03 PM
newaccord99
Jul 4, 2006 05:30 PM
bigracefan18
Jul 3, 2006 09:55 PM
ernie22golf
Feb 8, 2006 11:19 AM
The_Chronicle
Aug 11, 2005 04:27 PM
