2000 honda accord ex Radio ecu install help
Old Jul 18, 2010 | 01:04 AM
heymixter's Avatar
Default 2000 honda accord ex Radio ecu install help
Hi everyone, im new to the forums. I recently inherited my brothers 2000 honda accord ex and when he tried to install a aftermarket double din navigation everything worked fine, but the ecu went out on him about 10 days later. When we took the car to honda the supervisor told us that because our car had the honda code security system that we couldnt have a aftermarket radio. Is this true or did our ecu just happen to go out at about the same time as we replaced the radio. Any help would be great, thanks.
Old Jul 18, 2010 | 01:38 PM
keep_hope_alive's Avatar
the supervisor is wrong. the factory radio for 2002 or older Accords can be replaced without issues. now - if you messed up the wiring you could have caused the problem. did you use a wiring harness adapter? pic of the headunit wiring?
Old Jul 19, 2010 | 08:36 PM
heymixter's Avatar
I actually used a wiring harness that I purchased from ebay. Ive installed a few indash's in some of my other cars and usually dont have any issues, but dont ho I findas have to have the oem radio installed so that the car dosent think that its being stolen. Atleast thats what I figured. So if I give the another shot all I have to do is unistall the oem radio, use the harness to connect to the honda harness, and then wire that up to the new aftermarket radio, right? thanks
Old Jul 19, 2010 | 10:30 PM
assuming all of your connections are flawless...
i use high quality crimp connectors or solder and heat shrink. if the radio alarm wire is connected somehow, it would mess with the car. pic of your wire harness job?
is it a Metra harness? what model number?
MrMelokie
May 3, 2013 07:31 PM
live2rice
Sep 20, 2012 02:26 PM
jaystew
Mar 15, 2009 10:21 PM
RecMK5
Feb 13, 2009 06:33 AM
Tito
Oct 18, 2006 04:50 PM
