-   Audio/Visual Electronics (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/)
-   -   2001 coupe: running wires? (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/2001-coupe-running-wires-2037/)
chriswalker5 Feb 17, 2006 02:52 AM
While trying to install my sirius antenna, I was unable to remove the rear cup holder to feed the wire through the panel. Does anyone know if this is possible. I got it partially pulled up, but it would not come off. I am guessing i have to remove the whole panel. Does anyone have any suggestions or experience with this. I was able to run the wire under the backseat as a workaround, but would like to have a cleaner install.
I also plan on installing an amp in the trunk soon, so help would be greatly appreciated.
marbro Feb 18, 2006 12:19 AM
RE: 2001 coupe: running wires?
Yeah, I was trying to find a schematic on your car to see if there was anything different, most of the center console should be snap in with a few visible screws around the base. Honda tries to use as few screws as possible.
chriswalker5 Feb 18, 2006 04:58 AM
Thanks for the info...I am actually trying to take out the cup holder for the backseat, which is part of the panel where the door would be if it was 4 door.
lightshow Feb 18, 2006 08:25 AM
i would run the wires right up the middle instead, and take out the back seat.
