2001 coupe: running wires?
Old Feb 17, 2006 | 02:52 AM
chriswalker5
Default 2001 coupe: running wires?
While trying to install my sirius antenna, I was unable to remove the rear cup holder to feed the wire through the panel. Does anyone know if this is possible. I got it partially pulled up, but it would not come off. I am guessing i have to remove the whole panel. Does anyone have any suggestions or experience with this. I was able to run the wire under the backseat as a workaround, but would like to have a cleaner install.
I also plan on installing an amp in the trunk soon, so help would be greatly appreciated.
Old Feb 18, 2006 | 12:19 AM
marbro's Avatar
Default RE: 2001 coupe: running wires?
Yeah, I was trying to find a schematic on your car to see if there was anything different, most of the center console should be snap in with a few visible screws around the base. Honda tries to use as few screws as possible.
Old Feb 18, 2006 | 04:58 AM
chriswalker5
Thanks for the info...I am actually trying to take out the cup holder for the backseat, which is part of the panel where the door would be if it was 4 door.
Old Feb 18, 2006 | 08:25 AM
lightshow's Avatar
i would run the wires right up the middle instead, and take out the back seat.
torrguy
Jul 18, 2011 06:01 AM
90accord90
Jan 25, 2010 03:28 PM
Calevra18
Sep 16, 2007 10:45 PM
csnut18
Aug 2, 2007 09:05 PM
priscilla2237
Aug 1, 2007 01:20 PM
