2006 Accord radio and 12v socket not working
Old Jul 5, 2018 | 06:54 PM
Jwhite420's Avatar
Default 2006 Accord radio and 12v socket not working
Tried doing a sub install and when I got everything plugged up, I started the car then then radio and 12v lost power. I have checked all the fuses with a tester and they are all good, both under the hood and dash. I can not figure this out and wanted to reach out before I took it to get looked at. Any other possibilities aside from fuses? I have even tried a new radio.
Old Jul 6, 2018 | 02:36 PM
Under-dash Fuse No. 32 (7.5A) is the fuse in common for both the audio unit and the accessory power socket. There should be power through that fuse when the ignition switch is in the ACC (I) or ON (II) positions.
Have you checked whether there is power on both sides of that fuse when the ignition switch is in the ACC or ON position? If you have a voltmeter, measure the voltage.
kaivorth
May 20, 2012 12:28 PM
Jeepmarine
Jan 4, 2011 10:36 AM
HuYnHness
Mar 25, 2008 01:19 PM
c33pays
Apr 24, 2007 11:24 PM
newtohondas
Sep 17, 2006 03:38 PM
