2013 Accord LX rear camera
Hi
I want to install rear(back )camera on my LX (which dosen't have ) I asked someone to install but he said I have to change both LCD because on LX models the LCD won't connect to camera wire and it should be changed with EX models ! Is it right? If yes : Is there anyway to convert my LCDs input to camera output? so that without changing LCDs I could connect camera to it |
I don't have the schematics for the 2013 LX to compare with the 2013 Sport. They do have different model numbers, but so does the Sport and EX. That isn't to say that there isn't a location for a camera.
https://www.ebay.com/itm/2013-2014-H...M/272385254949 This model number matches the 2013 LX and has a connection for a rear camera. That is why you need to pull the radio to verify if the cable is already there. You can also look in the trunk lid for cabling at the rear camera location. The part number for a 2013 LX rear camera is 39530-T2A-A61 . |
Originally Posted by keep_hope_alive
(Post 381579)
https://www.ebay.com/itm/2013-2014-H...M/272385254949 This model number matches the 2013 LX and has a connection for a rear camera. That is why you need to pull the radio to verify if the cable is already there. You can also look in the trunk lid for cabling at the rear camera location. The part number for a 2013 LX rear camera is 39530-T2A-A61 . My accord has two LCD and that link is not for my car (Mine has cruise control, sun roof,two LCD ) Do you mean I replace LCD with this one you addressed? and if I change the LCD is there any chance to see camera pictures in upper LCD? |
Originally Posted by ghsouri
(Post 381581)
thanks for reply
(Post 381597)
By two LCD you mean the main unit is a touchscreen? In the US that head unit was only offered in the Hybrid, EX-L, and Touring trims and that trim had the rear camera and lane watch. Please post images for clarity.
The lower LCD is touchscreen the upper one isn't |
I haven't seen a base model with that head unit before. The A/C is base model but the radio isn't.
Are you the original owner? |
I've bought it recently
It's a middle east version .It's difference from US versions If I want to change the Audio system and replace it so I could connect rear view camera and also have navigation Do you know which part number should I order? and how many Item's should be changed? I want to order used ones |
(Post 381673)
It's a middle east version .It's difference from US versions If I want to change the Audio system and replace it so I could connect rear view camera and also have navigation Do you know which part number should I order? and how many Item's should be changed? I want to order used ones Maybe consider just trading the car in for one with the features you want? The upgrade you want to do isn't easy. |
Thanks for your reply
| All times are GMT -5. The time now is 04:20 AM. |
