2013 accord sport hid's
Old Oct 10, 2013 | 04:53 PM
Lnxserious's Avatar
Default 2013 accord sport hid's
Just got a 2013 honda accord sport i have no experience with lighting systems and I want to get some advice on brands kilowatts etc to use. I want hi beams lo beams drl and fogs.
Old Oct 13, 2013 | 12:28 AM
keep_hope_alive's Avatar
you will want HID kits made for your make/model/year so they take advantage of the reflectors/projectors. you'll need a place for each ballast for each lamp.
color temperature (measured in Kelvin) is to your preference (3000K vs 4300K vs 5000K). 4300K is usually the best bet.
wattage will need to match what the stock housing hand handle for heat, the stock bulb will be an indication of that. usually 35 watts.
start by making a list of what bulbs are in there now, and that will drive your vendor search for products.
the CBI bulbs are supposed to be really good:
D2S: Osram Xenarc 66240 CBI - HID Bulbs from The Retrofit Source Inc
and your car should take an H11 harness.
these kits are affordable if you are planning on a DIY custom install
Bi-xenon Morimoto Mini Stage III Kit (H1) - Complete Retrofit Kits from The Retrofit Source Inc
i recommend contacting the vendor to discuss compatibility before purchase. i've heard good things about The Retrofit Source.
An D. Nguyen
Aug 13, 2013 09:59 PM
Honda Editor
Jun 4, 2013 02:41 PM
VincentKarma
Dec 4, 2012 03:24 PM
Hardtopguy
Nov 28, 2012 10:56 AM
Jim Labruno
Nov 4, 2012 05:40 PM
