2013 Honda LED Look-alike Bulb?
Old Mar 1, 2013 | 11:49 AM
Spoolme's Avatar
how's your visibility at night now?
Old Mar 4, 2013 | 04:32 AM
xianmoon's Avatar
my visibility at night is not any different really. Changing out the bulb to LED doesn't really make a difference on the road haha. But I did change out my headlights for HID and that really made a difference. Also plan on changing my fog lights to HID lights real soon too!
Old Mar 5, 2013 | 02:22 AM
speedimp's Avatar
to me it the foglight is pretty much just for show. It doesn't work well in a real fog anyway. I was thinking of putting HID on the foglight as well... Instead, i use a LED bulb cuz it just looks nicer than halogen and produce less heat. HID on the headlight is a must tho and IDK y honda dont even offer that option .
Old Mar 13, 2013 | 12:08 PM
yardie87's Avatar
can you send me a link to where you got the led bulb for parking/DRL light
Old Mar 29, 2013 | 02:49 PM
happydude's Avatar
Hi,
If you don't mind, can you please give us the specs for the LED bulbs.
  • As mentioned earlier, you used a 168 LED bulb for the parking lights. Do you know the wattage and color (5000k)?
  • I'm also thinking of replacing the fog lights with LED, do you know what type of LED bulb I will need to replace it?
  • Is it straight forward when replacing the halogen bulbs with LEDs? (remove and attach?)
Thanks!
Old Apr 2, 2013 | 12:45 AM
speedimp's Avatar
Originally Posted by happydude
Hi,
Thanks!
for the 168 LED, i use a 68 LED . Check the link below:
Amico T10 68 SMD 168 194 1206 LED Car White Lamp Side Wedge Light Bulbs 10 Pcs : Amazon.com : Automotive Amico T10 68 SMD 168 194 1206 LED Car White Lamp Side Wedge Light Bulbs 10 Pcs : Amazon.com : Automotive
For the foglight, i recommand to use the one with CREE LED. I got that from ebay:
H11 CREE LED Projector Bulb Fog Daytime Running Light DRL Headlight H8 White 16W | eBay
and yes its direct replacement plug and play. UNLESS the led u gonna use on with a flash relay ie: turn signal bulb.
I hope that may answer your questions.
Old Apr 14, 2013 | 05:38 PM
  #17
happydude's Avatar
Thanks a lot! Very informational.
I see that u changed the rear lights with LED as well. Do you have a picture of it? I was wondering how it would look, would it make a big difference in terms of looks and performance?
Thanks!
Old Apr 28, 2013 | 03:13 PM
  #18
andy13nj's Avatar
Agreed, very helpful info.
I'm gonna try these in order to replace my parking lights with LED (to get that V6 look); and then replace the Fogs to get a diff look at night too.
I'll post pics before and after.
Old May 4, 2013 | 08:08 PM
  #19
andy13nj's Avatar
Dumb question - but, did you have to buy 10 of these 68 LED's for the parking lights? Is it 5 lights per side or something?
I did notice that the V6 model DRL which is the LED parking light below the headlights; looks like it has 5 LED bulbs in it. That's actually the look I'm going for.
Old May 7, 2013 | 10:36 PM
  #20
Jorge L. Ferreira's Avatar
I also need instructions how to change that little bulb underneath the headlight projector. I already purchased the LED, but I dont see a way how to remove the bulb because it is all the way to the corner of the headlight casing.
