2014 Honda Accord EX-L--Add Sub w/o Amp??
Howdy, Forum Members!
I see LOTS of discussions on adding after-market amps and subs, but I haven't seen a thread about just adding a sub. I replaced all the factory speakers with Rockford Fosgate minus the factory sub. I have a RF Punch 10" sub in a down-fire box just laying around. What if I simply unplugged the factory sub, ran extended wires to the Punch 10 sub without an after-market amp? It should give me something, right? |
Wow! This forum is dead.
Hey the idea you have may or may not work, because the factory audio systems are designed to be very efficient for little wattage. So that you have an aftermarket Subwoofer it may work just depends on the watts the factory amp will push out.
It's your need any additional car audio parts or installation kit head on over to Sonicelectronix.com and use discount code( AubreyH ) for 5% any purchases |
Originally Posted by alaskanseminole
(Post 374949)
I see LOTS of discussions on adding after-market amps and subs, but I haven't seen a thread about just adding a sub. I replaced all the factory speakers with Rockford Fosgate minus the factory sub. I have a RF Punch 10" sub in a down-fire box just laying around. What if I simply unplugged the factory sub, ran extended wires to the Punch 10 sub without an after-market amp? It should give me something, right? If you tap the sub output before the factory amp you get a flat, clean output you can feed into an amp for plenty if low end. |
He is correct on that better sound will need more power. Audio control makes one of the best interface for factory radios
Originally Posted by Moochdog
(Post 375007)
I know with bose audio systems in nissans each speaker has its own amp but as for your car I'll have to do some research on it I'm not sure if the amp powers just the sub or all the speakers. But add on to the factory system is easier. Taking the factory amp out my cause the radio to not work properly
(Post 375044)
Does that amp run everything or just the sub? I have a Rockford Fosgate Punch 10 in a downfire box. Thought about putting an RF mono sub under the seat to push it, but not sure where to hook it into? Replace the factor amp or in addition to?
The sub output from the factory amp is garbage. you want the sub output from the HU, accessible at the factory amp. I believe this will work fine, to intercept the signal before the amp while also using the factory amp for speakers. I haven't done that personally, though. You will need to disconnect the factory sub (remove it, preferably ). ANC must be defeated. |
