2015 hybrid touring subwoofer
Old Oct 25, 2014 | 04:13 PM
Know-boo Yuki Sasaki's Avatar
Default 2015 hybrid touring subwoofer
Im plannning to replace the infinity 8inch sub from the original.
2 questions
  • for the connector, i want to use the Metra 72-7800 (on amazon). do you think i can use it for subwoofer? (probably same as 2014)
  • i also want to know about rear speaker specs. its good, but if it can upgrade, then i should replace them at once. (probably change to KFC-1695PS)
Old Oct 26, 2014 | 12:07 AM
keep_hope_alive's Avatar
the rear speakers are by Foxtex. you will downgrade them with cheap coax. the stock system attenuates the rear speakers on purpose - you shouldn't notice rear speakers from the front - and everything should come from the front.
a straight sub swap won't make much of a difference either. the stock amp is the limitation and those who have gone for more power in the rear deck just have a ton of rattles. with enough deadener and foam you can increase the sub output without inducing ton of rattles, but it's more time than money.
mdoneil
May 27, 2015 09:56 PM
A.priori
May 7, 2015 10:54 PM
elbowroom
Jan 20, 2015 11:14 AM
iceblitzed
Sep 18, 2014 06:12 AM
RichW
Feb 25, 2014 10:45 PM
