94 Accord issues
Ive got a problem with my deck not turning off when i turn off my car, and take my key out.. I just installeda new deck in my car, while i was doing that, i decided to check all of my fuses and see if they were all good, since my dome light had stopped working.I replaced the one that needed to be replaced, which was called " interior back up " or something, and now, everytime i turn my car off, my deck stays on.And after all that, my dome light stilldoesntwork..( ive checked all the fuses inside, and under the hood of my car, and also the bulb ) Ifanyone has any informationabout my dome light not working,or my deck staying on, even tho mykeyis out of the ignition, thenlet me know, cuz itsgetting annoying!! Thanks!
-Steve |
RE: 94 Accord issues
Buy a new car
or give it to me. has the car ever been in a flood?
That could be alot of things. First, did the radio turn off with the car before? Did you replace the fuse with one of the same or less rating? Are you sure the swith for your dome light works, and isnt stuck somehow on the 'on' position? There could be a problem with wiring.
It could also be two seperate problems. Are any of the lights at the bottom of the door on when they are closed? If so, you may need to tighten the door latch. |
