94 Accord issues
Old Feb 5, 2007 | 02:07 AM
Eclips3's Avatar
Default 94 Accord issues
Ive got a problem with my deck not turning off when i turn off my car, and take my key out.. I just installeda new deck in my car, while i was doing that, i decided to check all of my fuses and see if they were all good, since my dome light had stopped working.I replaced the one that needed to be replaced, which was called " interior back up " or something, and now, everytime i turn my car off, my deck stays on.And after all that, my dome light stilldoesntwork..( ive checked all the fuses inside, and under the hood of my car, and also the bulb ) Ifanyone has any informationabout my dome light not working,or my deck staying on, even tho mykeyis out of the ignition, thenlet me know, cuz itsgetting annoying!! Thanks!
-Steve
Old Feb 12, 2007 | 09:34 PM
vtecHef's Avatar
Default RE: 94 Accord issues
Buy a new car
Old Feb 13, 2007 | 11:44 PM
manual123's Avatar
or give it to me. has the car ever been in a flood?
Old Feb 13, 2007 | 11:47 PM
19Accord97
That could be alot of things. First, did the radio turn off with the car before? Did you replace the fuse with one of the same or less rating? Are you sure the swith for your dome light works, and isnt stuck somehow on the 'on' position? There could be a problem with wiring.
It could also be two seperate problems. Are any of the lights at the bottom of the door on when they are closed? If so, you may need to tighten the door latch.
frankenstein69
Dec 28, 2014 12:36 AM
Ineedhelp
Jan 22, 2012 07:29 PM
thebartender2010
Oct 24, 2011 11:51 PM
GOT BOOST
Nov 2, 2009 08:32 AM
msheehan
Mar 31, 2005 01:18 PM
