Dash lights not working
Old Jan 7, 2012 | 06:11 PM
Richboy-7's Avatar
Default Dash lights not working
I recently changed the climate control panel on my 1998 Honda Accord 4 Cylinder. I noticed the same night that I changed the climate control that the dash lights went out. I changed the fuses and nothing has worked. I heard that it is most likely the drivers multiplex unit that needs to be changed but I'm not sure. Can anyone offer any help with this issue?
Old Jan 8, 2012 | 03:31 PM
keep_hope_alive's Avatar
Factory or aftermarket radio?
Old Jan 8, 2012 | 03:54 PM
Richboy-7's Avatar
After market but I've had an aftermarket radio in there for 2 years and it was fine until now
Old Jan 8, 2012 | 05:21 PM
I suspect you accidentally shorted out one of the illumination/dimmer wires by accident.
Or, the climate control module you swapped was different.
Old Jan 8, 2012 | 05:37 PM
Richboy-7's Avatar
Yea the accord I swapped it out from was a 2000 but I thought 98-00 were all compatible
Old Jan 9, 2012 | 08:19 AM
Richboy-7's Avatar
I also even switched the climate control panel back to the old one to see if that was the problem but the lights still didn't come back on
Old Jan 9, 2012 | 02:48 PM
no, if the panel is different then once you swap then damage is done. hopefully it is just the fuse(s). what fuses did you change? i have a 98-02 manual i can review.
Old Jan 9, 2012 | 05:14 PM
Richboy-7's Avatar
I tried switching the #9 fuze on the drivers side and also the #11 on the passenger side
Old Jan 12, 2012 | 08:43 AM
Richboy-7's Avatar
I still havent had the problem resolved. Can anyone give me any other advice on what it could be?
Old Jan 14, 2012 | 08:06 AM
i have been out of town all week, i will review the manual today.
