Does anyone have the same problem???
Old Mar 30, 2006 | 12:34 AM
Green_Accord's Avatar
Default Does anyone have the same problem???
I just recently installed an amp and an equalizer to my DVD player and upgraded to aftermarket speakers.. but after i've done everything, i noticed the car idles diffirently.. Did anyone ever have the same problem? Is it because the system draws to much power out of the alternator or is it something else? I did upgrade my battery to Optima and I'm thinking about getting the new ground system.. is it a good idea?? all ideas are appreciated..
Old Mar 30, 2006 | 02:12 AM
marbro's Avatar
Default RE: Does anyone have the same problem???
how many watts is your amp?
how much current does the dvd player say its draws?
If your running over 50amps constantly the answer is, yes most likely. The stock alternator only puts out 70amps max, and thats consideration of all the cars components being active at once.
The system being grounded with a larger gauge cable wont help you if your pulling more current then your alternator can put out. And in that process, your car battery will end up dying.
Had a friend who ran a 2400watt amp and his main battery was failing, the tac jumped everywhere and the engine almost stalled. It was funny as hell to see.
Old Mar 30, 2006 | 11:36 AM
accorddriverc's Avatar
you should look into a capacitor. I ma going to be installing one in my car soon because of my stereo. My lights dim even when I'm not really pumpin the music
Old Apr 2, 2006 | 03:44 PM
19Accord97
I recommend a capacitor as well. I've got an Aiwa stereo, Audiobahn 1,000 watt max amp, and two 500 watt rms subs and my headlights have never dimmed on me before. But, my volumes on less than half as high as it will go and my amp is turned up only 3/4 of the way.
Robert 1991
Mar 30, 2012 04:13 PM
spenceroma
Nov 18, 2011 12:31 PM
ebarrera661
Jun 22, 2010 02:17 PM
Aug 9, 2006 12:34 PM
TedsF23accord
Jan 15, 2006 08:57 PM
