Dynamat
Old Jun 9, 2007 | 08:43 PM
thug@$$n1gga
Default Dynamat
Anyone who has installed Dynamat in a 94-97 accord ; does a trunk kit have enough to cover enough of the trunk? Also, my sedan's 6x9s on the back speaker deck shake and rattle like hell when i turn the bass up, will dynamat on the bottom fix it? Ive heard different opinions on people with different cars as far as dynamat working. I want to do everything right the first time.
Old Jun 9, 2007 | 11:55 PM
MacLeod's Avatar
Default RE: Dynamat
Dynamat will work if used properly. If your speakers install is shoddy, then all the Dynamat in the world isnt going to help. If youve got your 6x9's running down to 20 Hz with the bass turned up on them and crank the volume from an overpowering amp with the gain set too high, its going to sound like crap.
That being said, if everything is installed properly and set right, then Dynamat is an invaluable tool to kill noises, rattles, buzzes and resonation. You can never have too much.
Old Jun 17, 2007 | 10:15 PM
Dazed's Avatar
Default RE: Dynamat
Hey Thug, im intrested in knowing how and what you did with the Dynamat. And if u fixed the rattle from the back 6x9s.
Want to know wat you did, to see what i can do.
Old Jun 17, 2007 | 11:36 PM
19Accord97
Default RE: Dynamat
Scosche makes their own version of Dynamat for cheaper. Might wanna check that out.
GMANCRX
Aug 16, 2013 10:31 AM
Moddage
Feb 23, 2011 08:07 PM
richomundo
May 4, 2007 12:01 AM
