-   Audio/Visual Electronics (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/)
-   -   HandsFreeLink Bluetooth Streaming (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/handsfreelink-bluetooth-streaming-57042/)
zponder Oct 19, 2013 11:31 PM
I just bought a 2012 V6 AWD Crosstour EX-L; no NAV. I've paired my Android phone but haven't found a way to stream Spotify over Bluetooth. I've also tried plugging my iPod Touch into the USB - HFL recognizes the iPod but does not stream the audio from Spotify.
Am I missing something or is this feature not available?
Thanks,
zp.
keep_hope_alive Oct 22, 2013 07:37 AM
does it play from music stored on the devices or other apps? - as a check that the pair is successful and audio streaming is turned on on the devices.
zponder Oct 23, 2013 08:01 AM
Hi, thanks.
The iPod did play locally stored music when plugged into the USB but I didn't try it over Bluetooth and I don't keep any MP3s stored on the phone. Phone calls work over Bluetooth.
I ended up just plugging my phone into the AUX port to play Spotify. This works, I just can't control playback through the car's console - which I can live with.
From what I've found by searching around, the HFL on the 2012's (at least those without NAV) don't have A2DP and won't stream high-quality stereo audio.
Thanks,
zp.
keep_hope_alive Oct 23, 2013 12:30 PM
Originally Posted by zponder (Post 334190)
Hi, thanks.
Thanks,
zp.
ok, that's why i wanted a test of A2DP itself first - to verify it's not the app but the communication. note you do have to enable music streaming separately from phone BT on your device - and sometimes per BT connection.
zponder Oct 26, 2013 09:54 PM
Ok, thanks - I'll double check that also.
Thanks again,
zp.
btlancaster24 Nov 11, 2019 07:44 PM
How do you "enable" music streaming from an app on your phone in order to use the USB port on either 2013 or 2014 Accords?
