how will these parts sound ?
Old Aug 29, 2006 | 06:02 PM
bpo145's Avatar
Default how will these parts sound ?
For an amp i am getting a 960 w soundstream 4 channel. for the speakers front and rear i am getting alpine type r`s. And for the head unit i am going with a an alpine CDA-9856. i think it should sound pretty good.
Old Aug 29, 2006 | 08:05 PM
marbro's Avatar
Default RE: how will these parts sound ?
whats the specs on the soundstream? And you cant go wrong with alpine, you just have to worry about over powering those speakers with a 960watt amp.... based on the wattage i would guess 120watt x4 at 4ohm but spec's would be needed, and i dont know too much about the brand in general
Old Aug 29, 2006 | 10:04 PM
trihonda's Avatar
So long as the install is clean, you can't overpower speakers.... In thoery, you could put a million watts of pure clean signal through a speaker. however, the first teeniest bit of signal noise or interference will send your speaker into a million pieces.
However, this is in an ideal world. Cars have interference and noise. So, make sure the install is uber clean.
Also, are you going to bridge two channels for a sub? and run the other two channels for your mid-high freq. speakers?
Regards. I don't normally comment on particular brands, as the manufacturing changes, and the sound is subjective. However, there are a few exceptions.... Jensen is a crappy brand, and high-end Oz are amazing speakers!
Old Aug 30, 2006 | 01:29 AM
marbro's Avatar
hehe, you have to keep in mind, theory is never practical, thats why i mentioned over powering being bad, but you will never find a perfect audio signal with a car stereo, let alone any other stereo, and this is also ignoring groups that intentional distort their music.
Old Aug 30, 2006 | 08:13 PM
bpo145's Avatar
Soundstream TRA960.4 amp
yea by the numbers this amp seems like overkill to the alpine type r`s which
have an rms of 55 watts and a max 275 watts. I heard the sound is much better
with a high powered amp like this. as of now i am not planning to bridge the
channels for subs but, that may be a possibility with this amp. Is the extra power
just overkill or will it make the music sound better? thanks
4-Channel Amplifier
120 watts x 4 chan. @ 4 Ohms RMS
240 watts x 4 chan. @ 2 Ohms RMS
Bridged: 480 watts x 2 chan. @ 4 Ohms
THD: < 0.02%
Frequency Response: 10 Hz - 50 kHz
S/N Ratio: >115dB
Damping Factor: >500
Input Sensitivity: 0.15 - 12.0V
Crossover Slope: 12dB
Crossover Frequency: 50 Hz - 5 kHz
Dimensions(in): 10.75x2.6x21.5
Variable high pass, band pass, low pass
Variable 18dB bass boost
Double sided glass epoxy SMT circuit board
PWM mosfet power supply
Tri-guard amplifier protection
SMT cooling fan built in
Tri-mode capable
Line output
1-year Sonic Electronix warranty
Old Aug 30, 2006 | 10:39 PM
marbro's Avatar
You most likely want to have the level at 1/2 to 2/3rds but youll tune it by ear anyways but it should sound good i hope the rear speakers are good freeair's tho, not sure how those actually perform
JDM Accord Wagon
Mar 31, 2012 09:07 PM
ryder_kid
Feb 14, 2012 11:28 AM
kal
Dec 20, 2010 08:52 AM
mrrght85
Feb 10, 2009 01:16 AM
BostonPuppyDawg
Jun 19, 2006 05:36 PM
