License Plate Rattle
Old Jan 10, 2006 | 12:15 AM
J dizzle
Default License Plate Rattle
What is a cheap and easy way to stop license plate rattle?
Old Jan 10, 2006 | 06:05 AM
lightshow's Avatar
Default RE: License Plate Rattle
do you have 2 screws or 4 in there? well either way. take out the two bottom screws if you have them, go down to popular surplus and get some one inch thick foam. cut out two little pieces and stuff it under your license plate at the bottom. whala.
now the real way to do it is to dynamat your truck, your system will sound so much cleaner and deeper, but its expensive.
lightshow
Old Jan 14, 2006 | 03:51 PM
Alizezaccord's Avatar
you can go with his method with dynamat or you can use it in combination with a liquid spray that deadeans sound and prevents rattle. You can get it from almost anywhere. I bought mine at NAPA and it works great. You can also use it in your trunk and on your trunk lid. You can use it almost anywhere in your car just be careful.
Old Jan 15, 2006 | 12:04 AM
AJ's Avatar
AJ
WHAT I DID WAS SOEMTHING SIMILAR TO LIGHTSHOW'S RESPONSE I REMOVED THE TWO BOTTOM SCREWS AND I STUFFED "WEATHERALL" A FOAMY SUBSTANCE FOUND AT HOME DEPOT FOR ABOUT 1.99 IN BETWEEN MY LISCENSE PLATE AND THE FRAM AND THE BETWEEN TEH CAR AND THE LICENSE PLATE. iTS CHEAP AND IT GETS THE JOB DONE.
YOUR TRUNK WILL RATTLE NO MATTER WHAT YOU DO UNLESS YOU GET DYNAMAT..WHICH IS ABOUT $100-$200..
Old Jan 15, 2006 | 11:08 AM
You dont have to spend a lot on dynamat. You can buy a custom wedge pack for 35.00 retail or check on ebay cause they been having deals on dynamat. Lightshows idea is also a good one thats cheap. Let us know how u do.
Honda_Dude
Mar 11, 2007 05:50 AM
savo
Jan 15, 2007 04:35 PM
jimbob312
Aug 30, 2006 02:26 PM
c0r5a38
Jul 13, 2006 12:42 AM
emaxxman
Mar 9, 2006 12:52 PM
