Need to make custom harness
5 Attachment(s)
Pictures attached.
I need a female connector from green to male connection to grey socket. Green is AUX in connector in center console. the grey socket is aftermarket dvd unit AUX connection. any help would really appreciated. thanks, this is for 2011 accord LX |
so you're trying to take the audio out of the aftermarket DVD and input to the factory AUX jack? and you want to hard wire or make a custom harness adapter?
you can try to make your own harness adapter, but it will be cheaper and easier to simply solder wire taps. you don't have to cut any wires, just peel insulation back and solder a wire on. you say 2 wires, but do you need more than 2 wires connected? you mean wiring 2 harnesses? |
Need to make connector
I finally able to get the connector diagram from manufacturer.
I have the following custom wire harness http://farm7.static.flickr.com/6136/...96dd9a35_b.jpg which need to be connected to car stereo AUX to this (white) connector http://farm6.static.flickr.com/5263/...50de18a0_b.jpg This is the wiring diagram of image 1 (wiring harness connector) that I got from manufacturer. http://farm7.static.flickr.com/6010/...2c123923_b.jpg Is there anything pre-made available or I have to make it by myself? Thanks a lot for your help. really appreciate that. |
i think you'll need to make one yourself, you're trying to mate a specific aftermarket DVD harness with a factory harness.
was this DVD player for a different vehicle? if so, you could find both matching factory harness plugs, then solder their wires together. nice find with the schematic! |
Originally Posted by keep_hope_alive
(Post 250357)
was this DVD player for a different vehicle? if so, you could find both matching factory harness plugs, then solder their wires together. nice find with the schematic! I think they may think that european accords and american accords are same. All other connectors fit perfectly except this one. Its 20pin connector which I think needs to go to my factory stereo AUX. I am trying to get a harness so I can make one by myself. where can I get the harness for 12pin something like this Amazon.com: Metra 71-1721 Reverse Wiring Harness for 1998-up Honda/Acura Vehicles Factory Radio: Electronics Ofcourse I need that or is there any alternate way to connect at the back of my stereo? |
can you atleast tell me what kind of connector fits on my factory stereo?
The amazon link for Metra 71-1721 is good for my custom harness connector. What kind of harness I need for my stereo? metra harness number would really appreciated. thanks, |
Oh, I didn't realize they were european vs. US models. I forgot or missed that above for some reason.
Metra is US products. I haven't looked for a European wire harness site... Yet |
well I can cut the grey wire so don't care finding the European harness.
On the back on my stereo the white connector, I need the wire harness for that. what partno I should look up for. |
Look on hondapartsdeals dot com. They will have harness information and purchasing options.
The metra harnesses are for main power/speaker and won't be for the AUX/changer/SAT inputs. PAC-audio and USAspec and GromAudio have products with the harnesses you need, maybe they would sell the harness only? |
do you have a description for the abbreviations used in the diagram you posted? i have a 98 accord and want to add the steering wheel control (i already bought on ebay) and a 1/8" stereo jack for my droid.
