Which OEM interface to use for 2010 Accord Coupe
Old Apr 13, 2010 | 01:26 AM
fattywinnarz's Avatar
Default Which OEM interface to use for 2010 Accord Coupe
I plan on connecting an OEM interface to my stock head unit to install amps and subs, but don't see which one to use for the 2010 Accord model. I've seen links to different ones on this site but none specify whether or not they work for the 2010 model, so any help would be appreciated.
Old Apr 13, 2010 | 01:48 AM
Default Hello New Member
Welcome to the forums...
E-mail or PM the Stereo Manager
keep_hope_alive
He will more than likely have an answer for you..
You can also PM t00fatt . he's also a stereo head here in the forums...
Attached Thumbnails Which OEM interface to use for 2010 Accord Coupe-cavslogo.jpg
Old Apr 13, 2010 | 12:39 PM
keep_hope_alive's Avatar
Pacific Accessory Corporation doesn't list their OEM amplifier interface for the 2010 model, it usually takes a year or so for some products to make it to market.
You could just grab the signal at the speakers and run them through an aftermarket OEM interface - like JL Clean Sweep. Alpine, MTX, Audio Control, Rockford Fosgate, etc. all have similar OEM interfaces. You just tap into the output from the factory amp and give that signal to the interface. Most of them will have a calibration CD that helps characterize and correct for any factory EQ. This correction makes them more useful than a standard line output converter (LOC)
Old Apr 13, 2010 | 01:09 PM
Talking Your Good Hope!
If I had a stereo shop I'd hire you in a New York minute
click the image..
Attached Thumbnails Which OEM interface to use for 2010 Accord Coupe-majestic238.jpg
Old Apr 13, 2010 | 11:19 PM
i aim to please. but i'd rather be designing the gear than just installing it.
HondaAccordEX94
Sep 23, 2010 02:32 PM
t00fatt
11
Jun 16, 2009 06:42 PM
slowryd
Mar 17, 2008 01:59 AM
thunder_x
May 2, 2007 08:39 PM
drugs!
Sep 5, 2006 04:46 PM
