OEM XM SAT antenna adapter for Sirius
10 Attachment(s)
after many different attempts at making an adaptable coax piece for the proprietary Honda XM antenna coax lead termination, i've found, through the combination of multiple RF connector parts, a solution that will enable one to use their OEM XM Honda antenna on aftermarket Sirius tuners or receivers.
some Honda have a Single lead: Attachment 23853 others have a Dual lead: Attachment 23854 either way, it will be necessary to remove the connector housing to expose the actual connector jack inside: https://i30.photobucket.com/albums/c...tennalead1.jpg once the connector housing is removed, the assembly of my parts can begin: Attachment 23855 adapter cable terminated in a RA SMB plug for the majority of car docks and direct tuners, however i can terminate to whatever your tuner or car dock accepts: Attachment 23856 copper collar and shrink tubing: Attachment 23857 assembly: Attachment 23858 Attachment 23859 Attachment 23860 then i place a shrink tubing sleeve over the connector body, shrink it with some heat, and you're done: Attachment 23861 ******** i also make a TRUE OEM Plug-and-Play version that simply requires you to unplug your antenna jack from the OEM XM Sat Tuner and plug it into my adapter cable, and it comes in two pieces- one for the adapter cable and the other, a 20 foot extension coax for interfacing with your aftermarket SAT receiver: http://i30.photobucket.com/albums/c3...r/PHTO0074.jpg http://i30.photobucket.com/albums/c3...r/PHTO0063.jpg http://i30.photobucket.com/albums/c3...r/PHTO0043.jpg http://i30.photobucket.com/albums/c3...r/PHTO0044.jpg Honda Accord XM Tuner location: Attachment 23862 if anyone is interested in using their Honda Accord OEM XM roof-mounted SAT antenna for their aftermarket tuner, please email me. Brian- mrbrianrwebb@comcast.net |
RE: OEM XM SAT antenna adapter for Sirius
Hi Member..looks as tho you did your homework on this subject and I will leave the post in this forum if you post the price for your set-up so that if any members wishs to have you make this up for them...then they will know the price..
WheelBrokerAng [sm=americanasmiley.gif] |
| All times are GMT -5. The time now is 04:56 AM. |
