OEM XM SAT antenna adapter for Sirius
Old Jul 30, 2006 | 07:19 PM
brianrwebb
Default OEM XM SAT antenna adapter for Sirius
after many different attempts at making an adaptable coax piece for the proprietary Honda XM antenna coax lead termination, i've found, through the combination of multiple RF connector parts, a solution that will enable one to use their OEM XM Honda antenna on aftermarket Sirius tuners or receivers.
some Honda have a Single lead:
others have a Dual lead:
either way, it will be necessary to remove the connector housing to expose the actual connector jack inside:
once the connector housing is removed, the assembly of my parts can begin:
adapter cable terminated in a RA SMB plug for the majority of car docks and direct tuners, however i can terminate to whatever your tuner or car dock accepts:
copper collar and shrink tubing:
assembly:
then i place a shrink tubing sleeve over the connector body, shrink it with some heat, and you're done:
i also make a TRUE OEM Plug-and-Play version that simply requires you to unplug your antenna jack from the OEM XM Sat Tuner and plug it into my adapter cable, and it comes in two pieces- one for the adapter cable and the other, a 20 foot extension coax for interfacing with your aftermarket SAT receiver:
Honda Accord XM Tuner location:
if anyone is interested in using their Honda Accord OEM XM roof-mounted SAT antenna for their aftermarket tuner, please email me. Brian-
mrbrianrwebb@comcast.net
Old Jul 31, 2006 | 02:37 AM
Default RE: OEM XM SAT antenna adapter for Sirius
Hi Member..looks as tho you did your homework on this subject and I will leave the post in this forum if you post the price for your set-up so that if any members wishs to have you make this up for them...then they will know the price..
Brogers84
Oct 14, 2010 01:04 PM
bpana
Dec 30, 2008 10:26 AM
captstef
Dec 7, 2008 08:30 AM
jprez1980
Mar 9, 2007 07:11 AM
billyloon
Jul 30, 2006 07:13 PM
