-   Audio/Visual Electronics (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/)
-   -   Radio code - Only accepts 4 numbers... (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/radio-code-only-accepts-4-numbers-18274/)
xray328 May 4, 2008 07:07 PM
Hi guys, noob here.
I'm trying to unlock my nav/radio. I have the nav unlocked, but with the radio I have a 5 digit code, but the radio only accepts 4 numbers.
I enter one number, it shows "C" then the second for "O" the third for "D" then the fourth for "E". Then it says ERROR 1.
So as you can see, it won't take 5 numbers. Any ideas?
RTexasF May 4, 2008 07:46 PM
RE: Radio code - Only accepts 4 numbers...
And your car is what?????????? The crystal ball feature went offline last week.
oldno_07 Nov 27, 2011 03:27 PM
Radio code only taking 4 digits
I have the same issue. 2007 Accord with radio/navi. Same description of issue. Takes 4 digits then fails.. I got the 5 digit code from Honda code website. help
neophyte Nov 27, 2011 09:05 PM
the code is wrong then. your deck should spell out code and the with the 5th digit it turns on. if it gives you an error you are not putting in the correct code.
each stereo has its own code.
keep_hope_alive Nov 29, 2011 06:27 PM
i concur that the 5th digit turns the radio on and you are getting an error due to the incorrect code. my Accord had two different codes in the glove box. one worked, one didn't.
neophyte Nov 29, 2011 07:07 PM
I too have two codes in my glove box. One is for the original radio, the other is for the one that replaced the original one when it went out.
oldno_07 Dec 2, 2011 01:22 AM
Alas. I called the honda support line, 800-999-1099.
I did not let her off the phone until she gave me the 4 digit code.
The 5 digit code she gave me was the same one I had.
So the code was wrong and it was not 5 digits.
I got the correct 4 digit code and will never lose it.
Don't get off the phone until they give you a four digit code
keep_hope_alive Dec 2, 2011 10:44 PM
Wow, that is a new one.
neophyte Dec 2, 2011 10:46 PM
care to share that 4 digit code so that it might be databased to help anyone else who may have this problem in the future?
oldno_07 Dec 18, 2011 02:05 PM
Sure
The 4 digit code that worked for my radio is 6099.
