shift light/shift alert
Old Oct 23, 2007 | 04:19 PM
thunder_x's Avatar
Default shift light/shift alert
i was in a friend's subaru sti and he said there's this thing (forgot the name). like he can set it to a certain rpm and whenever he reaches that rpm, the thing starts beeping to let him know. Then he would shift at that point. What is this thing called? And can we install something like this on our accords?
that would be a really cool thing to have
Old Oct 23, 2007 | 04:21 PM
sir_nasty's Avatar
Default RE: shift light/shift alert
yep, it's called a tachometer... *L* Actually you can buy just a "shift light"
http://www.streetbeatcustoms.com/10rpmtacwshi.html
Old Oct 23, 2007 | 05:11 PM
thunder_x's Avatar
well, im actually more interested in the beeping sound to alert me to shift, rather than having a light
is there anything like that available for accords?
Old Oct 23, 2007 | 05:22 PM
sir_nasty's Avatar
I don't know of any factory made systems but you could easily build one yourself. Just purchase a tachometer (see if you can find a small one) with a shift light, then disconnect the power leads to the light and hook them up to a buzzer (you can find one at radioshack), mount the system under the dash and then you have your buzzer.
Old Oct 23, 2007 | 06:10 PM
ORIGINAL: sir_nasty
That's a good idea there Spanky ..not bad thinking there!
Old Oct 23, 2007 | 06:15 PM
sir_nasty's Avatar
As they say "if you can't make it, fake it"
Old Oct 23, 2007 | 06:58 PM
nafango2's Avatar
wire the clutch switch up with a buzzer.
that way whenever you shift it buzzes so everyone thinks your always dead on.
but seriously some the higher end shiftlights most likely have a beep option.
Old Oct 23, 2007 | 09:08 PM
white95's Avatar
My Dodge Dakota has a shift light from the factory. I find it extremely annoying; the buzzer would drive me completely insane.
Just my opinion.
Old Oct 24, 2007 | 10:26 AM
falkore24's Avatar
put a switch and a rheostat on it for on-off and volume control
IAmATeaf
Jun 15, 2012 01:20 AM
Jerry_WA
May 13, 2011 09:16 AM
VWPowered
Sep 9, 2010 11:31 AM
L8RBRA
Jan 9, 2010 01:22 PM
Dj Insanity
May 21, 2007 10:05 PM
