some thing wrong with my audio
i have no idea what happen. i just use the air pump through the 12v in the car to pump some air in my tire and all of a sudden it just went out. then i try my radio, nothing work. it didnt even turn on. my car turn on normal, everything is fine but my radio not on why?
RE: some thing wrong with my audio
Most likely it blew a fuse ....
Here we go again.....[:@][:@]....... input year and model in your signature . so members who are trying to help you know what animal we are talking about |
sory dude 1998 accord ex
but where is the fuse locate?
Check your owners manual. There will be a fuse diagram/listing in tehre that tells you where the fuse is located and what fuse controls what.
ORIGINAL: badxdawgx818 but where is the fuse locate? this is the last time i will help you ,unless you input the info in your sign, that way we do not have to ask you again should you need future help and i am not trying to be an a**hole.. Anyho chk these 2 fuses , ,1 is fuse # 8 , 7.5 amps located in the underdash driver fuse box the other located in the passenger under dash fuse box,, # 9, 20 amps .. if either is blown .replace and retry .. |
thanks let me check
