some thing wrong with my audio
Old Apr 8, 2007 | 05:33 PM
badxdawgx818's Avatar
Default some thing wrong with my audio
i have no idea what happen. i just use the air pump through the 12v in the car to pump some air in my tire and all of a sudden it just went out. then i try my radio, nothing work. it didnt even turn on. my car turn on normal, everything is fine but my radio not on why?
Old Apr 8, 2007 | 05:36 PM
deserthonda's Avatar
Default RE: some thing wrong with my audio
Most likely it blew a fuse ....
Here we go again.....[:@][:@]....... input year and model in your signature . so members who are trying to help you know what animal we are talking about
Old Apr 8, 2007 | 05:38 PM
sory dude 1998 accord ex
Old Apr 8, 2007 | 05:43 PM
but where is the fuse locate?
Old Apr 8, 2007 | 06:23 PM
arexcrooke's Avatar
Check your owners manual. There will be a fuse diagram/listing in tehre that tells you where the fuse is located and what fuse controls what.
Old Apr 8, 2007 | 06:41 PM
ORIGINAL: badxdawgx818
Input year and model in your signature.. v6 or 4cyl , 2 or 4 drs
this is the last time i will help you ,unless you input the info in your sign, that way we do not have to ask you again should you need future help and i am not trying to be an a**hole..
Anyho chk these 2 fuses ,
,1 is fuse # 8 , 7.5 amps located in the underdash driver fuse box
the other located in the passenger under dash fuse box,, # 9, 20 amps ..
if either is blown .replace and retry ..
Old Apr 8, 2007 | 06:51 PM
thanks let me check
lakario
Aug 10, 2012 03:29 PM
hiphophead
Jun 30, 2011 07:59 AM
jonojo
Feb 19, 2009 01:29 PM
tru_44
Jul 16, 2007 10:23 PM
HundaAccode
Jun 11, 2007 08:09 PM
