Sub power help
Old Jun 27, 2008 | 03:12 PM
95accordman123
Default Sub power help
I have a Visionik powered sub in my trunk with the wires attached. I put it in today, but when i run my car the light for power doesent turn on. I changed the fuse for the amp with no sucess. I know its your all gonna tell me its big no no, but im running the power wire through the side of the hood near the door, than under the panel, than to my trunk. The Wire that i baught was to short to run to my battery, so i had to buy another wire and cut it and connect it to the fuse to the battery. I over checked the ground wire and RCA's and their all fine. I just can't figure out why theres no power going to my sub. The fuse on the power wire is brand new as well. Help would be appreciated. Thnx btw-its a 95 accord
Here are some pics:
Old Jun 27, 2008 | 04:03 PM
95accordman123
Default RE: Sub power help
photo added
Old Jun 27, 2008 | 07:53 PM
Tippman7641's Avatar
its funny a buddy at work had the same problem, same car, we just couldnt figure it out, i think it might be the ground make sure you have a connection, take a voltmeter and test the votage between the postive bat>amp and the neg amp>frame, you should get at least 10 volts
Old Jun 27, 2008 | 09:33 PM
slammed97's Avatar
Do you have the remote wire connected?
Old Jun 27, 2008 | 09:57 PM
wow ive done so many things, i forgot about that, thats usually the thing i make sure i do when i run the rcas to the head unit for the amp
Old Jun 27, 2008 | 10:00 PM
95accordman123
ya i have the rem wire connected.. im probably just going to remove evrything and start at scratch.
Old Jun 28, 2008 | 12:03 AM
Flatline1121's Avatar
I would double check the wire your using for the remote signal... sometimes people connect them to the amp/power antenna wire, and the car has no wire for that... it has happened to me before... try the red(switched power) behind the deck.
Old Jun 28, 2008 | 09:42 PM
95accordman123
could that be why the power light isint turning on in the sub?? from the rem wire not being attached right?
tru3_k177
May 25, 2008 03:56 PM
nate122
Jul 12, 2007 12:01 PM
mikel6690
Jun 7, 2007 04:43 PM
jdm_gadget
Jan 11, 2007 08:07 AM
Rizzie
Sep 16, 2006 07:57 PM
